Disk rear brakes on the S2
Hi there guys. I'm brazilian and the proud owner of a S2 red Escort XR3.
Since im starting to upgrade the engine (that is a VW/Audi 1.8 running about 100hp), I came up with the brakes issue.
In the puss' projetc thread he sais "Next stage was to fit the st170 brake set up,and focus rear disk conversion along with koni ajustable shocks and O.Z super leggeras in 17", as we can see in this pic:
So the question is, how do you guys make the "focus rear disk conversion" that seems so easy to do? What are the parts needed? Is it all plug and play stuff?
Hi mate all you need is the disks and calipers and you will need the bracket to bolt the caliper onto the hub. You could probably get them made over there or get them from one of the traders off here although i couldnt tell you who
As said, get the conversion plates, and it will all bolt straight on pretty much.
You will need a MK5 RS2000 handbrake cable and to change the kidney to the original one.
Easy peasy!
Easy peasy!
