909 parts updated
ATMSPORT LTD
Suppliers of all your new and used ford Motor sport 909 parts.
Escort Cosworth Gearbox /Parts
Fix it big tooth GPN box new £3,250.00
Fix it big tooth kit complete £ 2650
New Quaife 5 speed dog box 50 miles £ 3500
Twin paddle clutch complete £200.00
GPN Centre VC pumped up exchange £350.00
Motor sport Diff ‘s
9” CWP 4.6 NEW £300.00
New 9” FF plates Xtrac rear diff £3250.00
SOLD
Front diff strengthening plate Kit £65.00
7” plated rear diff complete £650.00
909 thick wall front diff £500.00
7 1 /2 3.9 diff rebuilt £ 475
Plated front and rear diff rebuild kits £ 750
New plated 9” rear diff unit £ 1650
MANY OSBOURNE BIG TOOTH GEARS HELD IN STOCK
WRC / GPA Parts
WRC IHI turbo complete £ 2000
LHD GPA rack used £700.00
4WD mountune big wing sump £280.00
LHD steering std fittings 1.7 turns £ 550
Mag 71/2 GPA sump complete £ 800
SOLD
Single paddle GPN clutch used £180.00
New LHD GPA Clutch cable £50.00
New RHD GPA Clutch cable £65.00
Escort full length sump guard £250.00
Tarmac carbon sump guard ( needs repair ) £ 150
Pair alloy front uprights complete £1,050.00
Front GPA flanges £ 150
Pair alloy TCA £500.00
Alloy front GPA top mounts a pair £200.00
9” Kevlar rear diff guard £75.00
Alloy 9” rear diff guard £ 50
Pair adj comp struts complete £300.00
.63 Turbo housing £150.00
GPA Square rear beam £450.00
Steel front GPA cross member £400.00
SOLD
New GPA turbo with 247 £1,650.00
GPA / WRC lightened fly wheel from £150.00
Alloy toe links £300.00
Pair 380mm x 34mm discs £200.00
Pair Gravel mag rear arms complete £1,400.00
GPA rear stub shaft £ 150
GPA rear flange £ 150
New 14mm steel wheel nut set £ 60
Pair 50mm GPA bilstien damper with roller bearing spring seats £ 900
P8 ECU with ALS £750.00
WRC AP clutch ( like new ) £ 400
Complete 315mm AP brake kit ( USED ) £650.00
Full set WRC Reiger dampers complete £ 3000
Pair WRC front top mounts £ 500
Pair GPA front top mounts £ 300
Pair rear GPA active dampers complete ( dash adjustable) £800.00
SOLD
Wide track front shafts complete £250.00
Alloy header tanks £45.00
909 alloy gear box mount £150.00
Alloy 909 rear diff mount £100.00
909 steering arms £200.00
Pair Rose jointed TRE and drums £350.00
New 8 injector WRC inlet manifolds complete £480.00
New Pectel 8 injector looms £545.00
P8 ECU for 8 injectors with ALS £ 1100
Used P8 pectel 8 injector loom £ 450
WRC bag tank complete with carbon cover £ 550
WRC twin fuel pump kit £ 300
New weld on chassis engine mounts £450.00
Weld on rear roll bar mounts £195.00
Kevlar inner wheel arches £ 200 a pair
Mag arm plastic protectors £ 250 a pair
Toe link plastic protectors £ 150 a pair
909 mud flaps £100 a set
Front GPA roll bars £ 180
New drop links kits £ 150
New roll bar clamp kit £ 150
ENGINES
1 ) WRC engine Tommy field spec, WRC motor sport 200 block , accralite pocketed pistons, BD 15 cams, WRC polished & ported head, 8 injection inlet manifold, big wing baffled sump, ALS spec, newly rebuilt never run, £ 8500
2) GPA cosworth engine, fully rebuilt, with motor sport 200 long studded block, ported head, WRC head gasket, BD14 cams, WRC 8 injector inlet manifold and fuel rail, New motor sport turbo for ALS, high pressure oil pump with oil spray system, lightened and balanced crank, new water pump, big wing baffled alloy sump, motor sport cam belt, New anti pump cam followers, Aero spec oil hoses, lightened and balanced fly wheel, all new seals and bearings, 6500 pounds
3) mountune spec clubman GPA cosworth engine, fully rebuilt, with motor sport 200 long studded block, WRC head gasket, New motor sport ALS turbo, high torque exhaust manifold, 4 grey injectors, ALS throttle body, high pressure oil pump with oil spray system, lightened and balanced crank and rods, new water pump, big wing baffled alloy sump, motor sport cam belt, New anti pump cam followers, Aero spec oil hoses, lightened and balanced fly wheel, AP paddle clutch, 4800 pounds
Motor sport Diff ‘s
SOLD Front diff strengthening plate Kit £65.00
WRC / GPA Parts
SOLDSingle paddle GPN clutch used £180.00
SOLDNew GPA turbo with 247 £1,650.00
ENGINES
Kiran1600E
11
Oct 2, 2015 11:35 AM
