Hows the best way to...
Old Sep 13, 2006 | 03:20 PM
MAD EVO 4's Avatar
MAD EVO 4
Default Hows the best way to...
Unseize a zetec bottom end
the head has been off for a while and so has the sump, and I cant turn it over
I need help please
Old Sep 13, 2006 | 03:23 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
scrap it and get another, its a lot easier and potentially alot cheaper
Bri.
Old Sep 13, 2006 | 03:26 PM
MAD EVO 4's Avatar
MAD EVO 4
Bri.
I'm theres another way mate
Old Sep 13, 2006 | 03:28 PM
Butch.'s Avatar
Butch.
leave diesel in the bores over night it will soak through thr rust and free it all up
Old Sep 13, 2006 | 03:29 PM
MAD EVO 4's Avatar
MAD EVO 4
cheers butch
Old Sep 13, 2006 | 03:31 PM
*Bri.4.b.Cos*
Well for a start the bores will be rusty so will need to be stripped and have the bores honed to remove all rust.
crank etc should be removed and checked for rust on the journals (should be ok as will still be oily.
Every thing should be stripped, checked and cleaned. Most likley it will be the rusty rings and bores that are stopping you from turning it over. If the rings are rusty you will need to replace them unless doing a budget bodgy build
Bri.
Old Sep 13, 2006 | 03:52 PM
MAD EVO 4's Avatar
MAD EVO 4
just need moving
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
pie-face
Sep 15, 2015 10:43 AM
