cars going on the rollers on friday-place your bets!RESULT
decided to get the car on the rollers on friday to see what power i now have.im happy with how it goes but just curious about its out put.
spec is
200 block,long studded,pocketed pistons,multilayer head gasket,ported head,bd14 cams,double valve springs,running rs500 inlet manifold and throttle body,850cc siemens injectors,t4 with 360 bearing,500 cooler,air injectors,l8 ecu live mapped by kenny at msd.
anyone hazard any guesses on output???
spec is
480?
Giving away what boost its running might be a useful clue to people though
Originally Posted by fordsportjay
Originally Posted by JonnyBravo
204
Got to be 450+ though really. Bit of a handful if its 2wd !
spec is 200 block,long studded,pocketed pistons,multilayer head gasket,ported head,bd14 cams,double valve springs,running rs500 inlet manifold and throttle body,850cc siemens injectors,t4 with 360 bearing,500 cooler,air injectors,l8 ecu live mapped by kenny at MSD.
PassionFords Creator
Originally Posted by Baldy Butch
where is the meet at then?
how far is it from northampton?? is it worth the drive??
Whose rolling road first?
its going on at system-r which is local to me.we did a rolling road day there a while ago.there was some doubt over some of the bigger power cars figures as they all showed good power(but they are all good cars to be honest), but a stage 1 sapph which i used to own and had recently been set up by msd ran 250 on there along with an escort rs turbo that is a consistent 230+ at other rolling roads ran 235,so im presuming the figures should be pretty accurate.
he does a lot of jap tuning there-mainly civic type r but there was a nice r33 skyline there when i went in today and an evo 6.
ill see what it does on here but im also more than happy to put it on anybodys rollers if there is some disbelief in my figures.i want to know as true as poss figure as much as anybody
what time is everyone meeting??
Im sure Its actually Junction 21A. Come off there, cross over to teh other side on teh bridge and there is a pub called the XXX XXX XXX? Be there about 8 i reckon...
**Any errors, please update it for me people.
mascrat manor
its sat on the rondabout on j21
from south come off at j21 take 3rd exit,go back over m6 and at the roundabout there is a small entrance(1st exit) onto the pub
cant miss it
cant miss it
got to be a good bit more than mine did Jay.
mine runs 28lbs of boost with a lot less spec so..........i would guess you should have very close to 500bhp.
fingers crossed.
fingers crossed.
