Removing ABS
Old Sep 12, 2006 | 02:04 PM
Liams's Avatar
Liams
Default Removing ABS
A friend of mine is looking at doing this, ive done it on my frst but his escort is miles different!Is there a post about this already somewhere? if so can somebody please put up the link? If not does anyone have a good guide on it!? Cheers in advance!
thanks
liam
Old Sep 12, 2006 | 02:27 PM
scotty86d's Avatar
scotty86d
I replaced the master cylinder with one from an xr3i, 23mm
took all the brake lines from said xr3i. removed everything to do with the brakes on the rst line wise and the compensators and the abs modulators.
then literally put all the new lines in, in exactly the same way as they were on the xr3i with the modulators in the front wing on the drivers side.
ask safe chav or someone like that as i'm probably not very clear to anyone else but myself
sorry if it isnt much use but its a fairly simple swap and thats coming from someone who isnt confident!!!
Old Sep 12, 2006 | 02:30 PM
craig rs's Avatar
craig rs
its easy m8 just done mine just follow the diagram below and block off the 2 pipes that lead to the abs system, also take out the standard rear compensators and get some off another ford mine were off a ka (situated near the rear wheels) and job done
Old Sep 12, 2006 | 02:42 PM
Liams's Avatar
Liams
Na that makes sence! Cheers fella il let him know, he is a mechanic so shouldnt be to difficult for him!
Sounds like theres a few ways of doing it? Il pass the info on!
Cheers lads
liam
Old Sep 12, 2006 | 07:36 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
tek the belts off
Old Sep 12, 2006 | 08:40 PM
Maxxeh's Avatar
Maxxeh
Is it really worth taking the ABS out? some people told me to do it but never knew how much difference it makes?
Old Sep 12, 2006 | 09:56 PM
Liams's Avatar
Liams
Taking the belts off is just bodging it! Hes wants it rid out the engine bay anyway! Abs is shite to be fair!!
Old Sep 12, 2006 | 10:01 PM
dave_y's Avatar
dave_y
what are the benefits of removing the ABS, my brakes (including standard ABS) work fine and stops me perfectly.
is there something im missing?
Old Sep 12, 2006 | 10:05 PM
Maxxeh's Avatar
Maxxeh
u got standard brakes? beocz mine lock a lot.
Old Sep 12, 2006 | 10:31 PM
dave_y's Avatar
dave_y
i have drilled and grooved discs and they are superb!
Old Sep 12, 2006 | 10:44 PM
scotty86d's Avatar
scotty86d
locking brakes can be down to shit tyres(often the case) worn brakes sometimes(rears ineffective) or your suspension being nackered, you just have to feel when they are going to lock and hold it there or back off. ive only driven a few abs cars and i far prefer non abs all the way!!!!
good luck with the brake swap, i personally recommend a full swap, you can see what state your full system is in,(mine was dangerous!)
Old Sep 12, 2006 | 10:55 PM
Maxxeh's Avatar
Maxxeh
I got brand new toyos and I also got new cosowrth dics and pads. Its wierd coz nothing happens until i put my foot down half way. And they lock at the worst times. Its a bit better when I pump the brakes.
Old Sep 13, 2006 | 05:42 PM
akito-man's Avatar
akito-man
mine locked with the belts off,
then again it was tested with teflon tech tyres,from the pound shop,some wankshaft fitted.before i owned it.
Old Apr 5, 2009 | 04:12 PM
blackfezzrst1985's Avatar
blackfezzrst1985
just a quickie, the abs on the frst is the same as on the erst? im going to take my abs off tomorrow!!
Old Apr 6, 2009 | 04:08 PM
addiction's Avatar
addiction
Removing the abs properly makes a massive difference to the brakes,the pedal feels much firmer and you get more feel in them.
The best way to do it is to use a non abs fluid reservoir and then remove the abs modulators which are bolted to the gearbox.Then just reconnect the pipes up correctly under the car and bleed the brakes.
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
