rs1600i rocker cover with turbo crossover pipe
Old Sep 12, 2006 | 07:25 AM
vx220's Avatar
vx220
Default rs1600i rocker cover with turbo crossover pipe
as above. what do i need to consider?
does some of it need to be removed?
is the oil filler up to use on a turbo car?
going on a fiesta RSt (hopefully) if that makes a difference?
EDIT TO ADD what about a spacer in the EFI manifold to lift the throttle body?
Old Sep 12, 2006 | 08:44 AM
Brookesy's Avatar
Brookesy
The oil filler cap will be up to the job as it twists on where as the cvh filler cap just pushs on.
The centre part of the cover may need drilling and have mounting bolts fitted to secure the cross over pipe
Old Sep 12, 2006 | 08:53 AM
vx220's Avatar
vx220
i wondered if it would go at all. the only ones i've seen fitted to turbos have been without the crossover pipes.
i thought it would be higher having the fins?
and would it be thicker being cast instead of tin?
any pics of one with the crossover pipe would be sweet!
Old Sep 12, 2006 | 08:59 AM
Brookesy's Avatar
Brookesy
Yes it will go on i think it miss's the fins.
This pic is from Fusion Fabrications website
Old Sep 12, 2006 | 09:04 AM
vx220's Avatar
vx220
brookesy, you're a star!
Old Sep 12, 2006 | 09:06 AM
vx220's Avatar
vx220
it looks like the one above has had some fins removed. see below
http://cgi.ebay.co.uk/rs1600i-rocker...QQcmdZViewItem
looks like out with the dremel!!!
Old Sep 12, 2006 | 09:11 AM
Brookesy's Avatar
Brookesy
lol have fun then
andy130
Oct 2, 2015 08:48 PM
Matt Baxter
Sep 16, 2015 08:30 PM
bigryrs
Aug 29, 2015 10:51 AM
Ford Focus ST Parts for Sale
Aug 28, 2015 01:32 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
