oil cooler
Old Sep 11, 2006 | 05:39 PM
batrst's Avatar
batrst
Default oil cooler
if you put oil cooler on erst do you take the water cooler unit on back of engine . and lope the pipe over so you can put the new oil sanwich plate in ,
cheer if any one can help
Old Sep 11, 2006 | 07:00 PM
Rick's Avatar
Rick
you should keep the std heat exxhanger. There is still room for a sandwitch plate if you use the stubby filter.
Old Sep 11, 2006 | 08:53 PM
batrst's Avatar
batrst
weres best place to get sandwitch plate from .
do i need any thng else
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
