not startin again
Old Sep 10, 2006 | 06:14 PM
rst230bhp's Avatar
rst230bhp
Default not startin again
Hello all
i changed my breather pipe today and the dam thing wont start
i have checked all breather pipes and clips,
it starts for a 2nd then switches off again.
any ideas
Old Sep 10, 2006 | 07:55 PM
Rick's Avatar
Rick
well, seeing as you've disturbed it, a breather system air leak is your first thing to checl. Oil cap not dislodged or anything?
First check in this situation, is to see if the metering flap is moving as it should be while crancking.
Old Sep 10, 2006 | 08:21 PM
rst230bhp's Avatar
rst230bhp
hi mate
yes the metering flap is moving when cranking i have checked all boost/breather pipes and clips, but still to no joy
oil cap is on tight
Old Sep 10, 2006 | 08:43 PM
Rick's Avatar
Rick
it could be you had a leak - and now you haven't, so she's running too rich.
It's trial and error. Get someone to crank it over, and you press the metering flap down a littler more, and see if she fires.
Old Sep 11, 2006 | 11:33 PM
rst230bhp's Avatar
rst230bhp
All sorted now
was the bloody fuel pump relay in the end
we bridged the wires so that the fuel pump runs of the ignition and
it fired up straight away, will be getting a new relay tomorow
thanks for your info rick
Amit
carl381
Apr 10, 2015 10:04 AM
chrisgcombi
Nov 2, 2014 08:41 PM
Tev
Sep 4, 2006 06:38 PM
andre_k
13
Jul 28, 2005 09:41 AM
