Fuse popped, help needed!
Old Sep 8, 2006 | 05:04 PM
ram's Avatar
ram
Has a large member
Default Fuse popped, help needed!
got a problem with my new fiesta rst.
pressed the heated rear windscreen button and i heard a fuse pop, and now battery light doesnt come on when ignition is on. (or when handbrake is up no handbrake light comes on the dash etc.)
its obviously affecting a whole circuit because the alternator is not charging the battery now either.
ive checked every relevant visable fuse and none of them are broken, are there any hidden fuses i may have not checked? it has an aftermarket toad alarm if this is of any relavence.
any help is seriously appreciated, as i cant drive the car untill i find this fuse!
Old Sep 8, 2006 | 09:45 PM
ram's Avatar
ram
Has a large member
fuse now changed, problem solved.
well almost..
charged up battery today due to alternator not working last night.
turn ignition so that dash lights come on, press key fob button to disable imobilser. turn key to start..but nothing engages!
im assuming its my imobilser not disengaging.
does anyone have a toad alarm?
need to find out how to disable it as i dont have manual for it.
cheers.
Old Sep 9, 2006 | 04:44 PM
ram's Avatar
ram
Has a large member
connector screw had worked itself loose on starter motor
sorted now
vrromm ppttsshhhh!!!
JoeyBoyden
20
Aug 22, 2015 03:23 PM
jaysoc1
Aug 20, 2015 08:18 PM
col93saphcos
Aug 7, 2015 03:21 PM
sjssms
Aug 2, 2015 07:01 PM
