Bottom balljoints
Old Sep 8, 2006 | 02:47 PM
TURBO BOI's Avatar
TURBO BOI
Default Bottom balljoints
if bottom balljoints are shagged, would there be play on the road wheel if you rock it top to bottom???
Old Sep 8, 2006 | 03:35 PM
addiction's Avatar
addiction
yes it would!! best way to check is to jack it up on the chassis then get someone to rock the wheel while you look underneath at the ball joints!
Old Sep 8, 2006 | 07:25 PM
NUTS RuS's Avatar
NUTS RuS
I doub't you'd see that unless your very strong as your pushing against the anti roll bar.
Play there would be wheel bearing.
Best way to check the TCA is take it off
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Fiddy
21
Sep 29, 2015 06:10 PM
SMILER258
Sep 28, 2015 09:04 AM
