extra security for me cossie
what extra security can i get for my cossie?
got disc lock, tracker and CAT 1 alarm
but as i leave it out on the street think im best fitting something else? like on the gearstick or owt?
If there is a post or something outside, get a big fuck off bike chain and wrap it round your wheel/axle to the post. I have the Immobiliser 3 bike chain with 16mm thick links
Cant get through it with a hydraulic cutters apparently
On a serious note. When my CAT1 toad was installed i opted for a level sensor to be put in which means if the car is alarmed and some pikey tries to lift the car up with a tow truck to pinch it the alarm is set off. Think it goes off after 5 degrees of motion is detected. Actually, thinking about it, it does work because i forgot to di-arm the car once whilst jacking it up and it went off. Nearly shit myself, but a good thing to have.
Originally Posted by BatFink
Originally Posted by Lambchop
stick a rottie in the boot
Funny as that tho
I think in this day and age if someone wants to nick a car, they will. At least with a Tracker you've got half a chance of getting it back.
http://www.extremeautoaccessories.co...p?section=1225 2nd from bottom if you want to goto the extreme
I hidden isolasion switch
I know a few unsavory people and they have said before that with alarms they know exactly where to go to over-ride them...But if someone puts a kill switch hidden in the car then that usually fucks them over
saff is working!!!...atm
if its that much ov a problem unplug a relay in the fuse box or take the coil lead off...... if they want it that bad they'll high-ab it away....lift it.... nick it....mine's been parked outside 4 2 year (touch wood)
mk3ste
Oct 17, 2021 10:09 AM
