Intersting failure, snapped the top of the throttle pedal!
Sep 8, 2006 | 12:02 AM
Is an RS500 one and a normal sierra saphire pedal the same?
Im guessing they are?
Sep 8, 2006 | 12:04 AM
Fat foot
Sep 8, 2006 | 12:30 AM
would look weird if it wasnt when the rest of me is
wish i had kept the spare ones from the 1600 that donated its shell, i bet they were the same
Sep 8, 2006 | 06:49 AM
That happened in my Escort cossie a couple of years back
The ball where the cable sat snapped off with part of the pedel.
I just got a m8 to weld it back on
Sep 8, 2006 | 07:15 AM
They are not the same.... the pivot point on the standard pedal is further down and the cable attaches differently too
Sep 8, 2006 | 07:22 AM
All cossie have the same t pedal which is not the same as any other sierra
Sep 8, 2006 | 07:35 AM
i think a cossie is the same as a 2.0i OHC
Sep 8, 2006 | 07:36 AM
Sep 8, 2006 | 08:06 AM
my clutch pedal is starting to break on the weld at the top
thought i needed a new cable
nothing that easy..
so is it a bit of a pig to remove the pedals then??
Sep 8, 2006 | 08:28 AM
NORTH YORKS RS SPARES i may also be wrong
Sep 8, 2006 | 08:37 AM
Quote:
Doh, thats going to make finding one today a lot harder than i expected then.
Will have a go at fixing this one then.
Thanks for the info
Sep 8, 2006 | 08:38 AM
I will have a look if i can find a 2.0i ohc one in a scrappy then i guess, they are starting to get quite rare in scrap yards these days compared to a few years ago when there was always a few sierras in every one!
Sep 8, 2006 | 09:22 AM
chip, give paul a ring, i expect hes got about 50 million of the buggers
granted you wont get it today but should do tomoz lol
as for how hard are they to remove, one 13mm nut inside the footwell, and one 13mm nut on the bulkhead in the engine bay.
peice of pee to remove
Sep 8, 2006 | 09:28 AM
Quote:
Originally Posted by fudgeass
chip, give Paul a ring, i expect hes got about 50 million of the buggers
Want to use the car tonight, so will whip it out after lunch and see if i can fix it or find one the same in a local scrappy, if not will call paul.
Sep 8, 2006 | 09:33 AM
ahh i see, off down weston sea front is it picking up the young'uns??
Sep 8, 2006 | 09:40 AM
PMSL
something like that
Sep 8, 2006 | 09:41 AM
rex647
Mar 6, 2022 06:20 AM
yatta
May 21, 2016 10:31 PM
