MOT's suck like cheap hookers
My car was MOT'd today. It was gonna pass even without CAT
But on arrival at the MOT station Duncan was greated by the external spot check MOT tester
So the plan was foiled
They had to fail it and it went on the system
Now I have to re mount the CAT and re test and then remove again
Im 2 busy to refit it myself so
Ive gotta get the CAT to him it be re fitted and re tested
extra cost etc
He said they are doing checks in Essex and Hertfordshire at the mo including road side tests
mega pi$$ed off
Now I have to re mount the CAT and re test and then remove again Im 2 busy to refit it myself so
Ive gotta get the CAT to him it be re fitted and re tested He said they are doing checks in Essex and Hertfordshire at the mo including road side tests
mega pi$$ed off
I got annoyed when i had my mini MOT'd a while back.. it failed on a couple of minor points, so i took the car away, and did the work, during the time i had my car at my house (only a couple of miles from the testing station) i did not use it... this was over a period of about a month.
When i went back for the retest, he found more points to try and fail me on, claiming i'd driven 3thousand miles!
Originally Posted by Dan
So you'd rather they didn't do their job properly and let loads of un-roadworthy vehicles out onto the public highways!?
Rules are Rules matey!
They're there for a reason
You only want them banned as mine sailed through it's MOT with a straight pipe on and it's about 20 years older than yours!
Originally Posted by John Laverick
Originally Posted by AlexD
Not long and it will be tax exempt ..
He's got you there Alex!
Kev, mine probably chucks out more pollution than yours!
he borrowed a used cat from stock and fitted it and when he called the MOT station to pop up for a re test they said the computer system has crashed and they can test
SMILER258
Sep 28, 2015 09:04 AM
