knocking noise help pleeeeeeeeeeeease
Old Sep 6, 2006 | 07:46 PM
fezzanut's Avatar
fezzanut
Default knocking noise help pleeeeeeeeeeeease
hey guys got a fucking dreaded noise intermittently whislt driving/coasting with foot on or off the clutch and its still there with the engine switched off.its the same sort of noise u get from a fooked outer cv joint on full lock but it happens in a straight line and sounds like its coming from the gearbox area,but i had a stage 1 cts lsd put in november just gone.maybe it could be the inner driveshaft joints?are they common or has anyone had a noise like this before?cheers
Old Sep 6, 2006 | 09:35 PM
NUTS RuS's Avatar
NUTS RuS
Does it change with road speed ?
How hard is the car driven ?
Have you jacked it up and checked for any play in the joints, as is those you suspect.
Old Sep 6, 2006 | 10:19 PM
Fewkesy's Avatar
Fewkesy
hey up mate! i have just had the same problem but i have found the fault to be the bolt had snapped on the rear gearbox mount! if i rocked the engine it seemed solid until i lifted the back and it lifted up. mine was knocking whenever i went on the throttle or round a corner or hit the smallest bump!
it could be worth a check if you haven't already!
Old Sep 6, 2006 | 11:11 PM
fezzanut's Avatar
fezzanut
yes it does change with speed but is not only noticeable at a certain speed if u know what i mean cos its intermittent.the car is driven hard and as a matter of fact it overboosted the day before this happened and the engine jerked violently 3 times.i swear i heard something fall off the car but im not sure.ive had it on the ramp and all seems fine tho i didnt check the gearbox mounts.shafts are solid.though my mate reckons the drivers side shaft is a bit egg shaped when coming off the throttle?no up and down movement in diff just in and out of the inner shafts.
tankybaby66
Feb 6, 2016 02:24 PM
gingeRS
17
Oct 2, 2015 09:42 AM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
rsturbo27
Sep 5, 2015 05:08 PM
