Can I remove my FORD alarm.
My std ford alarm is playing up, its got wet (small leak somewhere and has started playing up, causing the car to not start and cut out.) So I want to remove it. I have found the brain above the pedals but there seems to be a black wire. spliced into one of the wires going to the brain. This black wire I assume is attached to my aftermarket alarm.
Question is what do I do with it?
track.focus'd
Aug 12, 2015 05:53 PM
