Cossie Misfire
Old Sep 5, 2006 | 07:00 PM
Neil S's Avatar
Neil S
Default Cossie Misfire
I'm sure I remember reading about very similar problems on here in the past, so I'm hopeful that someone can give me some likely cuplrit(s) to save me some time trying to fix it. I've tried the search function, but it didn't turn up anything useful
I was out in my car last night, and intermittently when it comes on boost it basically dies. At the same time, the rev counter shoots past 7000rpm
I'm thinking CPS or Phase Sensor - surely it's got to be related to the ECU's speed calculations?
Can anyone help?
Neil.
Old Sep 5, 2006 | 08:49 PM
The Youth.'s Avatar
The Youth.
from memory neil it was related to ignition amp and or wiring specially the earths(something about multiple triggers), bulkhead multi plugs, then look at the crank and phase sensor.
steve
Old Sep 5, 2006 | 10:04 PM
ECU Monitor Enthusiast
As you originaly suspected its sounds like a classic phase sensor or crank
sensor issue to me.
Check the phase sensor inside the distributor to see if the wires inside
have decayed and are shorting out either with each other or
against the dizzi side wall - Very common.
Other wise, I would change the crank sensor first.
Old Sep 5, 2006 | 10:15 PM
XR Dougie's Avatar
XR Dougie
My best pals wont rev past 2000rpm and dies after the rev counter has a wee dance.
Changed the map sensor, phase sensor, plugs leads everything we can think of and still no luck so going to AVA to see what they think
Old Sep 5, 2006 | 10:17 PM
XR Dougie,
Didnt change the crank sensor then Try that next
Old Sep 6, 2006 | 12:20 PM
Neil S's Avatar
Neil S
Nice one, cheers guys.
I have a brand new spare CPS and phase sensor at home, will try those
Neil.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
