Idle Problem Now Sorted
Old Sep 5, 2006 | 10:16 AM
Phil DJ's Avatar
Phil DJ
Default Idle Problem Now Sorted
Finally sorted after nearly 10 months of owning the car.
Udated the idle valve and ecu and got it all set up correctly now so it finally runs right
Big thanx to safechav plus others who helped me out with the problems and pointing me in the right direction.
It's been very much appreciated.
Just got to get the other problems sorted now
Old Sep 7, 2006 | 08:39 AM
mattyfrstboy's Avatar
mattyfrstboy
Default your problem
what was the actual problem ive got a mate whose car idles at about 1500 when ticking over, also putting his foot on the brake makes it climb!
did you have this?
Old Sep 7, 2006 | 08:49 AM
Mr Shannon's Avatar
Mr Shannon
Mine Idles at 2k with the ISCV plugged in
Old Sep 7, 2006 | 05:10 PM
Phil DJ's Avatar
Phil DJ
The car idled at about 2k when it was warm sometimes. Had to turn the ignition off the start it again to clear it (it would happen again later tho).
Had to update the ECU and the ISCV to later spec ones
15
Oct 7, 2015 03:43 PM
RSmark84
Sep 13, 2015 01:29 PM
Marino
Sep 12, 2015 11:10 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
