Engine - Revised
Almost there!
Have for sale my engine.
has been up for sale in the past but then decided to keep it as new it was a good engine. but the bug for bigger power has had the final word and new engine has been purchased so needs to go!
Basically an almost standard spec....
was completely overhauled and re built about 15,000 miles ago
its had the bottom end rebalanced and had new mahle pistons fitted to a slightly lower compression ratio (7.7:1), obviously with all new bearings/shells/rings etc and in a 200 block
Standard head and cams with new valve guides etc.
fitted with a multilayer cometic head gasket.
engine has run beautifully and smoothly at all times.
Open to offers around £1500
Kelv.
Kelv.
Almost there!
Alternatively....
Have a spare exhaust manifold and T3 turbo, complete inlet plenum/fuel rail/injectors etc, starter and alternator.
so can be sold as a pretty much complete engine if required.
Complete with all the above £1750ono
or Bare engine £1450ono
