newbie help, just bought an RST
Old Sep 4, 2006 | 08:18 AM
RodgeRS_Turbo's Avatar
RodgeRS_Turbo
Default newbie help, just bought an RST
Hi people
just new to the site. I bought an RS Turbo last night.
However I have a problem with it. Runs good, smooth etc but when you open it full throttle is just closes down, if you hold the foot down it will hardly go over 1500 rpm, its like its on a VERY low rev limiter. it does it in any gear, its weird cause it runs sound apart from that - as I say, its only when its on FULL throttle
any suggestions would be mush appreciated
cheers
Old Sep 4, 2006 | 12:04 PM
scottbrown's Avatar
scottbrown
whats it boosting at? is the car chipped?
Old Sep 4, 2006 | 01:35 PM
turbo.jon's Avatar
turbo.jon
does sound like its running too much boost which is cutting it out as above is it chipped???
Old Sep 5, 2006 | 09:19 AM
RodgeRS_Turbo
im lead to believe its standard mate, still has original amal valve etc no adjustable valves etc been added. Maybe get a boost gauge to check, or is there a better way?
Old Sep 5, 2006 | 03:27 PM
Zetecfiesta's Avatar
Zetecfiesta
get a boost gauge just to check, the amal valve may be broke!?
Old Sep 5, 2006 | 04:45 PM
notSteveS2's Avatar
notSteveS2
check boost...
also r y sure theres no ir leaks???
Old Sep 5, 2006 | 06:21 PM
RodgeRS_Turbo
cheers mate, got one the day. any guides on fitting a boost gauge??
Old Sep 5, 2006 | 10:28 PM
HORNETS7's Avatar
HORNETS7
just really need to fit it into your dash and pipe from it and t piece it into the left hand pipe that goes into your plenum chamber top on engine!
Old Sep 5, 2006 | 11:35 PM
RodgeRS_Turbo
cheers, anyone got a photo of the pipe that I T-Piece into?
cheeRS
A.t.p
Oct 23, 2015 07:54 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
lime
Sep 25, 2015 06:56 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
