Highest boost on standard turbo?
i ran 18 psi on mine when it was standard bar an air filter exhaust and -31 actuator. Wouldnt recommend turning the boost up too much on a standard car though!!!! otyherwise it mite go BANG!
Don't ask - I don't know
Originally Posted by Lincolndanny
nope, turbo is standard with a -31 Actuator
You can run as much as you want.......BUT the more you run the shorter it will last.
15-17psi runs reliably for ages on a good condition turbo...I have heard of 22psi on standard turbos but its is v v in-efficient!
Matt Baxter
Sep 16, 2015 08:30 PM
