Noisey Tappets---How hard to change
Piece of piss Tiff.
Rocker cover off, rockers off, old tappets out, new tappets in, cover the lot in lubrication, rockers back in, clean the old gasket off the head/rocker cover, rocker cover back on with a new gasket. Don't forget the crossover pipe will have to come off to get the rocker cover off and I am not sure if the throttle body needs to be moved out of the way also.
sorry mate but when i said they had tappets once, some guzzer cunted me off, so thats why i dont say tappets but they fucking tap when they get worn! bloody things.
Originally Posted by Turbo Jay
You need to change the cam other wise your old one will chew your new lifters and theyl be tapping in no time all over again as your cam is worn
Best place for a new cam and lifters then????
I dont want an uprated one as i wont be tuning the car anyway
Originally Posted by TIFF
Originally Posted by Rick
Tiff you need to change cam too.
Is that an easy job too
Fitting new lifters alone will last all of a few minutes until the worn cam has munched them up again
A chip, actuator and set up can't hurt suerly?
I changed my tappets on my first (standerd) series 1 about 12 year ago and left the old cam in, it was BOB on tbh, well it was because i drove to Germany about a week later with no probs what so ever 890 mile trip
P.s my fookin back was in bits though
I MAY put it to 170bhp....but that would be it
Thats better!
Let me know if you do upgrade and you can have my ECU which is chipped already and my -31 actuator. You can always revert the car back to standard if you come to sell it then.
My car is having something else fitted to it instead.
