FINIS number required
Old Aug 20, 2004 | 04:37 PM
Moose 130's Avatar
Moose 130
Default FINIS number required
I am after one of the relays that are on a 2wd cossie engine loom.
There are 2 there, I have 1 already, I believe its the fuel pump one.
Its FINIS is 6149323
can somone tell me the numberr of the other one?
cheers
Old Aug 20, 2004 | 04:59 PM
Project ST's Avatar
Project ST
Could do with a bit more info - how many pins, what way they point, etc? Microcat's not being much help on this one - got either a page of applicable relays or a rough pic of the wiring loom.
Old Aug 20, 2004 | 05:22 PM
cossie1's Avatar
cossie1
if it's yellow (theres 2 next to each other) they are fuel pump relay and main relay (fuel pump one has a fuse inline) and they are both the same relay's.
If it's green then it's abs (this is all from memory mind) and I belive the purple / pink 1 is abs aswell
Old Aug 20, 2004 | 05:24 PM
Moose 130's Avatar
Moose 130
I have the yellow one.
There is only two plugs there, one yellow and one black. Both 4 pin relays.
Its the black one i am interested in.
They are not in the fuse box, but are under/behind the glovebox.
Old Aug 20, 2004 | 06:03 PM
stevedohc16v's Avatar
stevedohc16v
Heated front screen power and timer relays are mounted up behind the glovebox, could that be them?
Steve
Old Aug 20, 2004 | 06:11 PM
cossie1's Avatar
cossie1
yes 1 has a yellow plug yellow relay with a inline fuse (fuel pump I think) the other is a black plug with a yellow relay again from memory, the relay is the same as the other yellow 1
wowk
Mar 30, 2021 07:49 PM
20/20 vision
Sep 29, 2015 09:25 PM
