i need to lower the comprestion any ideas
Old Aug 30, 2006 | 03:03 AM
kiwixr3i's Avatar
kiwixr3i
Default i need to lower the comprestion any ideas
hi all
ive got a xr3i 1600
that im turboing at the moment
to just try a few things out.
i need to lower the compestion
i havnt got a set of rs pistons yet
as they are fucking hard to get hold of in
new zealand.
so what im wondering is there any other way to lower
the compretion ?
will consider any ideas at the moment
apart from skimming the pistons
thanks
Old Sep 2, 2006 | 04:49 PM
cos jon's Avatar
cos jon
Thicker head gasket, or spacer plate with std headgasket each side ???
Old Sep 2, 2006 | 04:58 PM
scotty86d's Avatar
scotty86d
I've heard before you can adjust the compression by bowling out the head(around the valve)creating more space?skimming the pistons works.
Old Sep 2, 2006 | 05:49 PM
cos jon's Avatar
cos jon
You can lower the compression this way but not by much, if your only after a temp solution till your pistons come i'd go two headgaskets.
Old Sep 2, 2006 | 05:54 PM
3dr wixsy's Avatar
3dr wixsy
Take the plugs out!! Sorry couldnt resist
Old Sep 3, 2006 | 10:53 PM
scotty86d's Avatar
scotty86d
its about 40 quid to skim the pistons and my local engineering place, so try yours possibly if you're taking the bottom end apart
Chas
Oct 5, 2015 07:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
roomey
Sep 19, 2015 08:40 AM
rogerxr3i
Sep 13, 2015 06:56 PM
rsturbo27
Sep 5, 2015 05:08 PM
