St24 brakes
Mates after some st24 calipers, his heard theres 2 versions, a larger and smaller 1, his after the larger 1!
my question is, are these the same as the 1's of a normal v6 (for example a n-reg 1)
Pez
Pez
Take your pick, it seems to be pot luck what type of claiper an ST has, mine takes the same pads as a 2.0l (probably what you call smaller caliper) car but obviously still has the larger disks.
