Fiesta RST Rattle plus missfire
Old Aug 26, 2006 | 04:32 PM
skip_rat's Avatar
skip_rat
Default Fiesta RST Rattle plus missfire
What started off as a occasional tapping from the engine has now developed into a loud rattling from what sounds like the top end of the engine. The engine has developed a missfire as well. The noise goes at tickover and the missfire seems to clear too, both come back if you rev the car.
A compression test showed no problems, not that I was expecting it to.
Is this just the usual CVH tappet problem or something more serious as I've never known it to cause a missfire? The problem has developed over the last 50 miles to the stage that the car is undriveable now.
Old Sep 12, 2006 | 08:13 AM
sexr3i's Avatar
sexr3i
isn't it
cam lobe could be worn to the point where its not opening the valves enough to let a the air/fuel mix in at low air speeds ie, tickover.
Old Sep 12, 2006 | 09:58 PM
Rick's Avatar
Rick
Above is very likely the reason. Worn cams cause missfire's and rattles just as you describe. Compression won't be effected, as the valves will still be shutting. I have worked on a lot of RST's with your problem, and it is nearly always down to the cam.
A.t.p
Oct 23, 2015 07:54 PM
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
