XR3i clutch
Old Aug 26, 2006 | 03:31 PM
3i_gaz's Avatar
3i_gaz
Default XR3i clutch
will a fiesta turbo clutch and gearbox bolt straight onto my 1985 mark 3 escort XR3i?
cheers boys
Old Aug 26, 2006 | 04:26 PM
SafeChav's Avatar
SafeChav
The clutch won't fit, yours has a 200mm clutch, anything after 86 is 220mm, and why would you want to fit a FRSt box, theres near on no difference? (it won't fit anyway)
Old Aug 26, 2006 | 06:54 PM
3i_gaz's Avatar
3i_gaz
just me mates got one there, and mine is on its way out. (pops out of reverse and 4th is a bit notchy)
if i fit the turbo flywheel will that fit ok? and then i can use the larger clutch as well?
cheers
Old Aug 27, 2006 | 10:20 AM
SafeChav's Avatar
SafeChav
Yes if you for the larger flywheel it will fit
The gearbox won't have the front mounting point present
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
