2wd saff breaking, rs500 block
2wd saff, all parts available
all running gear
ecu
loom
engine built using a genuine rs500 block, hybrid t3, built by interpro with receipt £1300
engine without turbo, manifold, inlet £1000
what ever your after just ask. sensible prices
all running gear
ecu
loom
all running gear
ecu
loom
all running gear
ecu
loom
engine info,
2wd head
standard cams
rs500 block (standard bore)
4x4 pistons, rods
2wd inlet & exhaust manifold
there is a engine number stamped on the block, i will find out what it is and add it later
2wd head
standard cams
4x4 pistons, rods
right nearly everything has gone,
parts still for sale;
bootlid
rear bumper
cloth interior
level 6 ecu (chip to run dark blue injectors4x4)
side skirts
2wd calipers
i think thats about it
bootlid
rear bumper
cloth interior
side skirts
2wd calipers
dojj
28
Sep 11, 2015 10:00 PM
