saph rev counter in 3dr?
Old Aug 19, 2004 | 03:57 PM
B11GNS's Avatar
B11GNS
Default saph rev counter in 3dr?
would it work? The reason being my rev counter is under reading and i have tried changing the coil (made no difference) and have checked the wire from the coil to the clocks (all ok), so i can only try changing the revcounter itself, the thing is a saph one will be cheaper and easier to get hold of as i only need it to try out, if it does turn out to be the rev counter then i can go and get a 3dr one.
Old Aug 19, 2004 | 04:20 PM
B11GNS's Avatar
B11GNS
Old Aug 19, 2004 | 05:42 PM
B11GNS's Avatar
B11GNS
come on, someone must know!
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
martynhomer01
Oct 1, 2015 12:05 AM
Russ Payne
Sep 25, 2015 08:29 PM
