PC Bods..
Old Aug 21, 2006 | 10:59 AM
AndyBlackFRST's Avatar
AndyBlackFRST
Default PC Bods..
Hey,
Was wondering if there is any way to monitor the amount of data being put through my wireless router.
I ahve got one installed on my pc... But want to see how much the other guys in the house are using.
Any ideas?
Old Aug 21, 2006 | 11:06 AM
BM08's Avatar
BM08
what exactly do you mean by data? like how much bandwidth and downloads everyones doing? if so net limiter is good or so ive heard
Old Aug 21, 2006 | 11:18 AM
AndyBlackFRST
Will Net limiter monitor my whole connection.. Or just how many Gb of data is downloaded/upleaded
Old Aug 21, 2006 | 11:30 AM
Dan B's Avatar
Dan B
Net Limiter will only monitor YOUR computer, it won't monitor the other peoples' machines unless they're using your computer as a gateway (which would make a wireless router kind of pointless).
Your best bet would be to look into whether your router supports SNMP-querying (check the manual, ask the manufacturer/vendor) and, if so, to look at a program like PRTG (a free SNMP-management program, that would let you query your router for whatever information it stores via SNMP).
Old Aug 21, 2006 | 11:42 AM
BM08's Avatar
BM08
Ahh the man in the know! i stand corrected
Old Aug 21, 2006 | 11:48 AM
AndyBlackFRST
UI can see how many packets of data have been through the router.. But nothing else
Old Aug 21, 2006 | 01:44 PM
Dan B's Avatar
Dan B
If set up correctly, on a decent router that supports it properly, SNMP can be a very powerful tool......as an example (albeit not a good one, since no home-user is going to be using a Ł750,000 router on an ADSL connection), here's what we're graphing (and monitoring, using another program) on one of our major routers in work:
Main CPU Load
Routing CPU Load
Traffic inbound (on every port)
Traffic outbound (on every port)
Interface errors (on every port)
Packets dropped (SYN and ICMP, on every port)
Flaps (on every port) *a flap is when the interface drops and comes straight back again
Internal temperature using built-in sensors
Number of routes announced (on any port using BGP)
Each graph is set up to update every 5 minutes, and the monitoring system checks each value every 5 minutes against threshold rules configured within itself, and will alert (via audible noise, email, and SMS to the on-call mobile) if any value goes outside of these thresholds.
So yes, configured properly SNMP is a very powerful tool......but, as I said, you'd need to check if the router you're using will actually support it...
Old Aug 21, 2006 | 01:49 PM
Jim Galbally's Avatar
Jim Galbally
your ISP will probbaly have a "check your usage page" if it's a capped connection, use that
Old Aug 21, 2006 | 02:53 PM
AndyBlackFRST
I'm on NTHell... So no limits..
Will have a look when I get home though
Old Aug 21, 2006 | 10:12 PM
Jim Galbally
if youve got no limits, why do you care?
Old Aug 21, 2006 | 10:18 PM
Adrian's Avatar
Adrian
3 words:
Fair Usage Policy
NTL run one, even thoughwe are uncapped.
Old Aug 21, 2006 | 10:20 PM
Jim Galbally
well, they haven't had a go at me and ive had cable since the day it came out.
netlimiter tells me i downloaded 345gb last month
