turbo not holding boost
Old Aug 20, 2006 | 03:29 PM
robmillarf's Avatar
robmillarf
Default turbo not holding boost
my fiesta has had a t3 conversion and the turbo i bought for it has covered all of 1000 miles but now is not holding its boost, its boosting at .75 and faids to .5 around 5500 rpm
can any one please help
will turning the boost up help
and wot can u turn a t3 stage 1 boost too
cheers rob
Old Aug 20, 2006 | 03:41 PM
Oranoco's Avatar
Oranoco
Sounds like it's just not set up.
I'm assumin your measurements are in bar in which case it's peaking at 0.75 (11psi) and dropping to 0.5 (7.25psi) which would sound about correct, maybe a slightly soggy actuator. I wouldn't DIY this at all and get a tuner to set it all up as there is more than just boost pressure to worry about with a T3 as it moves a larger volume of air at any given pressure
GavStyli's Avatar
GavStyli
Kasapis
you cant just turn up your boost yourself as you dont know if its fueling is correct. anyhow turning up the boost wont help! could be a weak actuator
you should be testing this in 4th gear btw
Matt Baxter
Sep 16, 2015 08:30 PM
gchristophi
Aug 31, 2015 10:36 PM
Marcus L
Aug 29, 2015 02:18 PM
IAN RS2k
Aug 18, 2015 07:51 PM
jay030787
Aug 17, 2015 06:16 PM
