URGENT - REAR ARM BOLTS TENSILE RATING
Aug 19, 2006 | 12:51 PM
Does anyone know what is the tensile rating of the rear arm bolts on en esc cosworth, are these 8,8 or 10,9 ??
Aug 19, 2006 | 01:10 PM
8.8 minimum.
10.9 is a bit overkill, but no harm is using them
Aug 19, 2006 | 01:13 PM
Cheers mate, just thought i'd check as one side was 8,8 and the other 10,9 !!
Aug 19, 2006 | 01:18 PM
Its not uncommon for someone to put new bolts in after they have had the arm off
Note - new nylock nuts MUST be used everytime they are removed
Aug 19, 2006 | 01:36 PM
the boilts must be a min of 12.9 hence why theyare blue as std signifies high tensile for ford
Aug 19, 2006 | 01:38 PM
12.9
I always assumed they were 8.8
Aug 19, 2006 | 01:51 PM
defo 12.9 pal, hence the blue colour, all fords high tensile stuff is blue
Aug 19, 2006 | 01:52 PM
The blue bolt on mine is a 10,9, just phones ford and they said the red ones are 12,9,
They did confirm that they should be 10,9 ie blue but as usual they don't sell them anymore !!.........
Any good online bolt shops !!!!
Aug 19, 2006 | 02:02 PM
in fact ive just had a look, and the blue ones are 10.9
the ones i replaced them with are 12.9,s
Aug 19, 2006 | 02:04 PM
REAR ARM HIGH TENSILE BOLTS - WHERE CAN I GET THEM
Thanks for checking, i nearly put 3 x 8,8 back in with one 10,9, they have been on the car for longer than i've owned it too !!!
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
