Engine Rebuild - (but going EFI)
Old Aug 16, 2006 | 02:50 PM
Diamonds.'s Avatar
Diamonds.
Default Engine Rebuild - (but going EFI)
Whats the best way?
My engine is a good engine but will at some point need a rebuild, and i wanna restore her to looking the muts nuts again. engine, bay, etc.
Its done just under 70k but has been well used in the past lol. i dont want to rebuild that engine i want to start a fresh, so i can still drive her in the meantime etc. its going to be a slow little project so will be done for next summer.
Now what should i do. I want to make it a stronger engine than standard but not OTT.
Do i buy a fooked FRST engine but has a good block or what?
Havent a clue so would like ya imput please
i know i will have to buy the EFI bits as she is still MFI at the mo
cheeRS
Rob
Old Aug 16, 2006 | 07:07 PM
Noisy Boy's Avatar
Noisy Boy
Why not rebuild you bottom you have already got and then the know you have a strong bottom end, cos at the end of the day all rs bottom ends will be old and you will rarely find a strong one ready to use.
Old Aug 16, 2006 | 07:23 PM
Rick's Avatar
Rick
No need for fiesta stuff. U can use what you have. How mych power do u want?
Old Aug 16, 2006 | 07:31 PM
Diamonds.'s Avatar
Diamonds.
Noisy Boy reason i wanna use another engine is to give me something to do but keep mine going for now. but replce everything in the new engine new (if i can) lol
Rick i got 200bhp 220lb/tq with a foooked actuator at the mo. but tbh not much more than that again. just want to go EFI (bit of a flutter lol) few stronger bits than standard and something for me to do as a project
Old Aug 16, 2006 | 07:43 PM
Noisy Boy's Avatar
Noisy Boy
oh ok mate well you still dont need a frst bottom end either way S2 or a frst if your going to rebuild it there no need to worry my son! If you have no worry about getting a knacked one you can get one no problems.
Old Aug 16, 2006 | 07:45 PM
Diamonds.'s Avatar
Diamonds.
cheerRS dude
Old Aug 16, 2006 | 09:28 PM
Rick's Avatar
Rick
Fiesta management is prob a little easier to fit, but it's a bit cack - but will see u to around 220-230 hp. A fiesta block has the flywheel and CPS in the block for this, and it's quite neat. Cossie management gives u far more scope, u can use ur existing block, and use 1800cvh cps and pulley for timing info to the ecu. Cossie management requires a custom mounted cam sensor, but gives better economy imo than OFAB/C. You will need either a fiesta head - or if urs is good - a spacer to mount the injectors in.
Old Aug 19, 2006 | 01:34 AM
Jade1's Avatar
Jade1
thanks rick
EoinXR3
Sep 7, 2015 05:44 AM
s1turboman
Aug 29, 2015 04:27 PM
Dahl88
Aug 22, 2015 08:16 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
