pressure sensor
Old Aug 16, 2006 | 05:21 AM
gus's Avatar
gus
Default pressure sensor
can you get a sensor that will light a warning lamp when a pressure has dropped
i wanna run it in my fuel line so i know if pump has stopped or not flowing enough
just so i can switch to 2nd pump
Old Aug 16, 2006 | 07:09 AM
Eagle's Avatar
Eagle
Super Moderator
what sort of pressure you looking at ???
as i might be able to help you
dangerous - reyland's Avatar
dangerous - reyland
you could buy a SPA Gauge gus.
will show the pressure & you can set the low pressure warning light
Old Aug 16, 2006 | 01:48 PM
GARETH T's Avatar
GARETH T
theres lots of pressuer switches which you can use
really you need to use a differatial pressure switch
Old Aug 16, 2006 | 02:03 PM
Eagle's Avatar
Eagle
Super Moderator
one that switches on when pressure drops..
Old Aug 16, 2006 | 03:41 PM
GARETH T's Avatar
GARETH T
http://www.attf.info/itm0p75.htm
not very nice looking,, but you get the idea
Old Aug 17, 2006 | 05:02 AM
gus's Avatar
gus
thanks chaps
will pass this info on to me eletrically minded chap
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
SMILER258
Sep 28, 2015 09:04 AM
