dipstick, oil reading on a saph
Old Aug 15, 2006 | 10:01 AM
Cawood's Avatar
Cawood
Default dipstick, oil reading on a saph
are these pretty inacurate?
i changed the oil at the weekend, checked the dipstick last nite
and its well below min, only just shows a drip on the dipstick
i had used the car about 30min before i checked it, rang my mate who has a cossie 2 and he said he gets the same
it cant have used/leaked all 3.5 litres already
Old Aug 15, 2006 | 10:24 AM
SapphyMike's Avatar
SapphyMike
mines always been fine when i check it..
did you check it again a bit later, was it the same??
Old Aug 15, 2006 | 10:45 AM
Cawood's Avatar
Cawood
nah dint check it again as my road is a very steep hill, n didn't want to leave it at the bottom of the road for rite long
i'll av another scan 2nite
Old Aug 15, 2006 | 10:58 AM
SapphyMike's Avatar
SapphyMike
hmmmm, cant you check it somewhere else thats level?
do you go to work in it?
Old Aug 15, 2006 | 11:25 AM
gingeRS's Avatar
gingeRS
min on the dipstick is not 3.5 litres
just keep it topped up, always check on level ground, and make sure you push the dipstick RIGHT into its tube.
the difference between min and max is about a litre i think
Old Aug 15, 2006 | 12:30 PM
Cawood's Avatar
Cawood
i know that! thats why i am panicing!
nah i dont use it for work mike, when i get home 2nite, im gonna park it at bottom of the road again n leave it for 1hr then check the reading again
i've topped it up again with anoth 1/2 litre last nite, made no difference
so that 4litres its got in it now, n it shows fook all!
Old Aug 15, 2006 | 12:34 PM
SapphyMike's Avatar
SapphyMike
make sure you are putting the dip stick in all the way, oh, and that it hasnt snapped the end off lol
Old Aug 15, 2006 | 12:36 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Make sure that the level is checked on a cold engine aswell - you'd be surprised at just how much oil sits in the castings on the head and doesn't fully drain back to the sump
Old Aug 15, 2006 | 12:42 PM
Cawood's Avatar
Cawood
i bet you its summat as daft as that, or me sticking it in the wrong hole!
graceland could we bet that as well actually, cos before hand i'd been out in it for a good 30 min, i did leave it for another half hour to cool tho before checking it
Old Aug 15, 2006 | 12:44 PM
SapphyMike's Avatar
SapphyMike
it does take a while for the oil to drain back to the sump, but tbh, id expect at least a half level reading after half an hour!
Old Aug 15, 2006 | 12:59 PM
Cawood's Avatar
Cawood
well i'll find out 2nite
i'll park it somewhere different n check
Old Aug 15, 2006 | 01:08 PM
Phil's Avatar
Phil
Jeebus
Definitely leave it off for as long as possible before checking the level.
Ian1964
12
Jan 26, 2021 11:57 AM
155lee
Oct 27, 2015 04:55 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
dojj
28
Sep 11, 2015 10:00 PM
Adam Graham
Sep 6, 2015 06:04 AM
