Spec of turbo from large turbo escos
Old Aug 15, 2006 | 09:22 AM
Stu.H's Avatar
Stu.H
Default Spec of turbo from large turbo escos
is it a t34 .48?
Im presuming so as to minimise lag as much as possible?
Old Aug 15, 2006 | 09:23 AM
T34.63
_DAN_'s Avatar
_DAN_
Yoon
T34 .63
Old Aug 15, 2006 | 09:24 AM
_DAN_'s Avatar
_DAN_
Yoon
Damm you to hell chip
Old Aug 15, 2006 | 09:25 AM
Seems a bit of an unpleasant ending to wish on someone just for trying to be helpful
I hope you die of aids.
Old Aug 15, 2006 | 09:26 AM
Stu.H's Avatar
Stu.H
pmsl
what are the differences between the .48 .55 and .63?
just a brief explanation or it will go over me head
Old Aug 15, 2006 | 09:27 AM
Originally Posted by Stu.H
pmsl
The bigger numbers are phsyically bigger.
(ts actually a size relative to the wheel itself)
bigger = more power + more lag
Old Aug 15, 2006 | 09:28 AM
_DAN_'s Avatar
_DAN_
Yoon
sorry man.
Old Aug 15, 2006 | 09:29 AM
Stu.H's Avatar
Stu.H
Thanks Chip
And what comfortable boost do they tend to hold easily?
Old Aug 15, 2006 | 09:31 AM
Thanks Chip
It is very dependant on what engine they are on, as its about flow AND boost, so on a 6 litre v8, they would struggle to make much boost at all, especially at higher rpm as it would be swallowing the air too quickly.
But on a YB all will spike to 2 bar+, but none will hold it right to the limiter comfortabley.
Old Aug 15, 2006 | 09:35 AM
Stu.H's Avatar
Stu.H
Its going on a 2.1ZVH with acralite pistons.
I spoke to alexzvhcabrio and he said unless the pistons had been skimmed, it may struggle to make big boost. The engine was built by burtons and Im not sure of what their policy is with that.
JUst had comfirmation they have been "dished" and the compression ratio is 7:1.
Old Aug 15, 2006 | 09:37 AM
Piston skimming wont really effect if it can make boost, more just wether or not it makes any power when it does, as if you dont have a low enough CR you have to have the timing heavily retarded to avoid Det.
at 7:1 though, the skies the limit i should think, although ive not mapped one personally.
Old Aug 15, 2006 | 09:44 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
No no, he clearly means the ENGINE wont be able to take it.
That turbo could to 35psi to the rev limiter all day long on that engine IMO.
Engine wont do it tho
Old Aug 15, 2006 | 10:13 AM
Stu.H's Avatar
Stu.H
Thats what I meant stavvy
I've just booked car in for final map on 28th, so will see what Karl advises
Cant foooookin wait
SmudgerByName
52
Jul 28, 2016 06:14 PM
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
james kiely
Aug 28, 2015 08:58 PM
c20tbo
Aug 17, 2015 10:19 PM
