2/4wd inlet, throttle body swaps etc
Old Aug 14, 2006 | 07:38 PM
Mr C's Avatar
Mr C
Default 2/4wd inlet, throttle body swaps etc
Been looking this up and trying to find answers in the archives about sapphires but no good info as yet so;
Will a 2wd throttle body fit a 4x4 inlet
will a 4x4 plenum cover fit 2wd trumpets (any difference between trumpets?)
will a 4x4 cover and elbow fit a 2wd trumpet with 2wd fuel rail
whats the differnce in fitings for a 2 and 4x4 fuel rail if any.
Which is better for throttle response, flow etc Im running 330bhp Phew thanks
Old Aug 14, 2006 | 08:21 PM
CosKev3's Avatar
CosKev3
All 2wd and 4x4 inlets and plenums can be mixed and matched
(not 100% sure about small turb esc cos though )
If you use a 4x4 plenum you will have to make a bracket to bolt the 2wd fuel rail to the plenum
The front mounting point is in a different place
Pretty sure 4x4 plenums are less restrictive than 2wd
Fitted a 4x4 plenum to mine,and a plenum spacer,only because I was having it live mapped though
Old Aug 15, 2006 | 06:08 PM
Mr C's Avatar
Mr C
thanks for that. Anybody got a pic to illustrate the front mount position difference? Are the swedish type plenums built with a certain fuel rail in mind then? if so is it 2 or 4wd?
Old Aug 15, 2006 | 06:11 PM
Everything will be made for 4x4 fuel rail.
Old Aug 15, 2006 | 06:48 PM
Mr C's Avatar
Mr C
right OK then does the 4x4 inlet give better throttle response too or just improve power and torque too?
Old Aug 16, 2006 | 10:23 AM
CosKev3's Avatar
CosKev3
Think the inlet manifolds are the same
Just the plenums are different
Old Aug 16, 2006 | 10:32 AM
foreigneRS's Avatar
foreigneRS
Testing the future
if you use a 4x4 plenum cover, you're better off using also a 4x4 fuel rail with it than modifying a 2wd one to fit, as the FPR is fixed to the rail on 4x4 not with a shonky length of hose like on a 2wd.
i did that, but brazed on the quick connect end from a 2wd so that i could still use a 2wd fule supply pipe and remove/refit it easily
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
