sapphire boot floors
im currently doing a bit of a resto on my sapphire, just started stripping underneath unfortunatly the spare wheel well is quite rotten with a few holes in it, can the boot floor be removed or is it a case of cutting the rotten bit out and replacing it with a good second hand one?
its not too bad just the actual bottom where the wheel sits, think ill cut one out of another car and weld that in.
also removed the rear bumper and skirts today, look what i found
fit a new sill mate
can you make most of it yourself it isnt to hard
if you think thats bad look at my project
http://www.rs-mania.co.uk/forums/ind...opic=8423&st=0
think reshell is going to be best at the moment as everywhere i look on this one its rotten, so far it needs:
both sides inner sills
both sides outer sills
drivers side rear quarter
passenger side outer arch
drivers side inner arch
rear panel
spare wheel well
quite alot of work there and with paint etc its going to be easier and cheaper to just use it as a donor for another shell.
rear panel
spare wheel well
may just do that mate, although ill wait until ive got the cash together first.
still im going to keep this shell and just attempt to do the work myself, lol i reckon its days are numbered then, going to take the angle grinder to the rear quarter today
Orion_Gav
Sep 29, 2015 04:50 PM
