What ECU do I have
Old Aug 13, 2006 | 04:57 PM
xr3-keith's Avatar
xr3-keith
Default What ECU do I have
Hi all, can anyone tellme what ecu i have
IT BLUE RED AND BLACK
Thanks in advance
Old Aug 13, 2006 | 05:22 PM
Rick's Avatar
Rick
series 2, pre 90 spec, needs knock snesor.
Old Aug 13, 2006 | 05:33 PM
xr3-keith's Avatar
xr3-keith
How you mean, will it not work without knock sensor???
Thanks for any help and info
Old Aug 13, 2006 | 06:00 PM
SafeChav's Avatar
SafeChav
This is what i was telling you about
It works without a knock sensor but because you have a series 1 there is no wiring so the ignition curve will be very flat
And as im sure Rick will agree, seeing as you have a series 1 get the proper ECU which doesn't need a knock sensor.
Old Aug 13, 2006 | 06:22 PM
xr3-keith's Avatar
xr3-keith
Ok thanks
It a S2 lump in a mk3 escort using a S1 Loom and a S2 ECU, so do I just run some wire to the ecu from the knock sensor to right the problem Im gunna have
Old Aug 13, 2006 | 06:38 PM
Rick's Avatar
Rick
yes - although be nicer if u can get an s1 ecu - as the knock sensors are problamatic.
Old Aug 13, 2006 | 06:44 PM
SafeChav's Avatar
SafeChav
Originally Posted by Transit Killer
Ok thanks
To the Fuel ECU - NO
To the ignition ECU yes
Old Aug 13, 2006 | 06:45 PM
SafeChav's Avatar
SafeChav
Just re-read what u said and i swear u said fuel ecu
ignore me im nothing
Old Aug 13, 2006 | 08:10 PM
xr3-keith's Avatar
xr3-keith
Thanks guys, will let you know how it goes, should be running tomorow
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
