zoo old stock clearance
8x17 rl7s 4 of powder coated £900
3 billet -6 fuel rails £80 each
4 billet -8 rails £120(polished)
10mm plenum spacers with bolts to suit £40
uprated top mounts were £60 now £30 a pair
rs turbo rear brackets £20
focus brembo to cozzy 2wd brackets £60
focus to rsturbo hubs £80
-10 alloy billet fuel rail blanks £20 each
kent double valve springs and ally caps standard hieght £100 brand new in box
escort cozzy intercooler £50
200 block with pistons to suit (.05 fresh bore) 500
alloy top mounts ajuastable brand new £80 pair
new set ajustble tcas complete £175
set rl7s conditon unknown yet with tyres (fuked) full set 8x17 et33 (will check offset
£500 as they are or £650 blasted checked for cracks freshly painted any colour (cash up front )
set 2wd konis £150 no springs
some 2wd and 4x4 zoo beams ready to be painted one payed for £650 fitted
Hi Brom,
Whats the uprated top mounts? I suspect it is for the top of the front struts yeah? If so is there bushes in it? I have powerflex top bushes and I am sure the top of my coilovers are moving under load.
Thanks
Graham
Thanks
Graham
the top mounts are the metal cone ones which i make beef them up and re zinc them
the are brand new ford items welded up and re zinked
this stops the top mounts cracking on koni and even more coil overs
cheap fix and very quite as you still use the sandard rubber bush
i can get a pic up or just look in march fast ford mag there a pic there what they do
no sorry jan i have not recived a email
please pm one i having email trouble as it is
Originally Posted by BROM@ZOO
yes mate depending on wheel fitment
Do you know how the offset of the Brembo caliper/disc compares to the standard 2wd caliper/disc.
Do the brembos stick out more or less than the standard 2wd brakes?
The reason I ask is because im already running 3mm spacers to clear the standard calipers and dont want to go any thicker.
My tyres like to say hello to my arches now and again as it is
i have a set of porsche 4 pot calipers and focus rs discs to fit to my 3 door and was wanting some brackets made up but i dont know which model they are off will i have to send the caliper to you also the direction arrow on the caliper will be pionting the wrong way will this matter(or can the link pipe at the bottom of the caliper be swapped for the bleed nipples)
thanks in advance
maca hogg
ps could you send me a rough price thanks
thanks in advance
maca hogg
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
Adam Graham
Sep 6, 2015 06:04 AM
