2wd saff cossie
Ive owned her for around 2yrs now, spent loads on her, £3000 down engine advantages, alot of the work has been done in the last year, been 100% reliable since all work has been done on it.. Reason for selling, want a 3dr..
Spec:
Flint grey (2wd)
T&T
Lots of history
4X4 Bonnet
Twin Headlight Conversion
17in Alloys
Dump Valve
Boost Gauge
B&M Quickshift
S/S Exhaust
Drilled Discs with performance pads (fronts)
Grooved discs with performance pads (rears)
Green Injectors
3Bar Map Sensor
-31 Acuator
T34
New Gearbox (fitted july 05)
New AP Racing Clutch (fitted July 05)
New Radiator (fitted July 05)
Cam Followers (Fitted July 05)
Head skimmed (feb 06)
cosmetic head gasket fitted (feb 06)
New valves fitted (feb 06)
Rolling roaded at 329bhp (feb 06)
Bad Points:
Stone chips on bonnet
Small amounts of bubbles of rust on drivers door
Bearing in mind when i brought the car it was almost standard so as you can see spent alot money on her and its been well looked after..
(P.S) Escort Cossie wheels and RS500 Front Splitter not included in sale..
£3800 o.n.o
PM if intrested or phone 07709314574
email: xr21981@aol.com for pics
Spec:
Flint grey (2wd)
T&T
Lots of history
4X4 Bonnet
17in Alloys
Dump Valve
Boost Gauge
B&M Quickshift
S/S Exhaust
Green Injectors
3Bar Map Sensor
-31 Acuator
T34
Bad Points:
£3800 o.n.o
dojj
28
Sep 11, 2015 10:00 PM
