Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Changing heater matrix on 1999 Escort
Old Aug 12, 2006 | 07:28 AM
spadey's Avatar
spadey
Default Changing heater matrix on 1999 Escort
Hi there, apart from my RS i also have 1999 escort diesel van but when I put the heater on warm it doesnt blow out warm air or rather it does for a second or 2 but then basically blows out cold air.. I have been told it is the heater matrix so was wondering how to change it? Any tips are appreciated, also if anyone has 1 for a 1999 escort van let me know? Cheers
Old Aug 12, 2006 | 01:15 PM
dave green's Avatar
dave green
If I was you I would disconnect the two water hoses that go to it and flush it out. and see weather the water passes through it. as the matrix dont normally block up.
Dave
Old Aug 12, 2006 | 03:10 PM
spadey's Avatar
spadey
Default re matrix
Hi mate, thanks for that but how exactly do I do that? Do I need to take the dash off or can I do it in the cab quite easily? Any help is great thanks
Old Aug 12, 2006 | 04:07 PM
dave green's Avatar
dave green
You do it from the engine bay. disconect the hoses that pass though the bulkhead. and sick a hose pipe up one of them and see if the water passes thought the matrix.
Dave
Old Aug 12, 2006 | 04:24 PM
spadey's Avatar
spadey
Default re matrix
Any chance you could tell me exactly which pipes I need to disconnect and where to shove the hose pipe and where the water should come out? Also if the water does come out then why else would warm air not come out of the heater panels? Thanks
Vincereese
Jun 1, 2023 09:14 AM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
FlashRS
Sep 14, 2015 12:36 PM
cameron2
Aug 25, 2015 07:18 AM
Vincereese
Aug 18, 2015 03:57 PM
