Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
escort cabriolet efi what can i do to it?
Old Aug 7, 2006 | 04:04 PM
libro's Avatar
libro
Default escort cabriolet efi what can i do to it?
I've got a 91' Escort cabriolt 1.6efi and i wanna get a few more bhp under the bonnet but i aint got a clue where to start.
if you can give us a hand be well appreciated cheers!!
Old Aug 16, 2006 | 07:57 PM
The Blue Overal's Avatar
The Blue Overal
Default About Your Car
Hello I think that you should put on a pipercross or k/n cone filter induction kit, magnacore leads blue or red But blue are for lower supression or the red ones are for turbo charged cars, splitfire plugs or bosh which you car would probobly run better off as you have bosh management system. 4 inch tail pipe scorpian exhaust. Put in a chip for your ECU system. You would then need to upgrade braking system from rear drum to disk conversion but you didn't say if you model had ABS. You might want to think about lowering it for more stability Bilstein or Koni adjustable suspension.
Hope this helps alot.
Regards James
Dr. Ickxs
Sep 15, 2015 10:15 PM
RSmark84
Sep 13, 2015 01:29 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
bigryrs
Sep 7, 2015 06:45 PM
