Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
4X4 COSSIE LOWERING SPRINGS
Old Aug 7, 2006 | 01:09 PM
COSSIE 1's Avatar
COSSIE 1
Default 4X4 COSSIE LOWERING SPRINGS
Im after a set of lowring springs for my saph 4x4 cossy must be in good nick and im lookingat a 25mm-30mm drop cheers .......i know i can get a set of chassis dynamics springs for £78 but there might be a set unused or part worn out there cheers
Old Aug 7, 2006 | 04:04 PM
Dirty Harry's Avatar
Dirty Harry
Super Moderator
take some advice mate DONT drop the front as it causes all sorts of expensive problems like drives shafts popping out which can smash the side out of your gearbox and wrecked untold amouts of parts,if you need to lower at least fit adjustable TCAs so this doesnt happen,or the trick is to get your car sat nice and level change the rear springs only to 2WD items,you will find the car sits perfect
Old Aug 7, 2006 | 08:14 PM
THE RADMAN's Avatar
THE RADMAN
i have some eibachs,the best you can get i/m/o see for sale section
Ben26
Aug 27, 2015 08:56 PM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
A.t.p
Aug 15, 2015 11:37 AM
RsS2daz
Aug 14, 2015 05:26 AM
