loose ht leads?
Old Aug 6, 2006 | 10:09 PM
BLING_IAN's Avatar
BLING_IAN
Default loose ht leads?
hi ive got blue magnecor ht leads and they keep poppin off the dizzy cap!
... do u need a special dizzy cap for magnecor leads or has the previous owner possibly fitted the wrong leads??
Old Aug 7, 2006 | 07:50 PM
Noisy Boy's Avatar
Noisy Boy
I had a same problem with motorsport leads they should with a strong push stay on?
Old Aug 8, 2006 | 09:05 AM
rstel1's Avatar
rstel1
also mate if you have used silicone under your bonnet to clean it they may slip off take the leads off one at a time (so they stay in order) and clean the dizzy cap and then like noisey boy says give them a bit of a push
Old Aug 8, 2006 | 03:00 PM
r-s-turbo's Avatar
r-s-turbo
mine did pop off a couple ov time sn i woz runnin on 3 cylinders! how embarrasing! yeh u realy have to push them on hard, they sorta like click on, if u dont feel em click on they ent on properly.
Old Aug 8, 2006 | 06:24 PM
rstdave's Avatar
rstdave
Had the very same problem with the ford motorsport ones...load of shite them! No matter what i did they wouldn't stay on, they'd normally fall off when i was racin someone and i hit the limiter, leavin me on 3 cylinders
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
The Youth.
Sep 30, 2015 09:59 PM
pabloXR
Sep 21, 2015 12:42 PM
landaqmabba
Sep 15, 2015 07:16 PM
