v6 mondeo
Old Aug 6, 2006 | 07:03 PM
lee23's Avatar
lee23
Default v6 mondeo
can any one help i have just got my hands on a v6 mk 2 si mondeo nad it is leaking power steering
fluid can any one tell me how much i will b looking at to get this put right and also what i have got my self in to please thanks
Old Aug 7, 2006 | 07:59 PM
James's Avatar
James
First off where is it leaking from? if it's from the pipes that join to the reservior this is common so just replace with normal hose clamps.
If it's leaking from the rack gaiters then this is a bit more serious and don't expect much change from Ł300 at a garage as it needs a new rack.
Old Aug 7, 2006 | 08:05 PM
xr4x4rs's Avatar
xr4x4rs
id recommend changing the water pump if it hasnt had one
there plastic propellors and tend to snap
Old Aug 7, 2006 | 08:23 PM
BM08's Avatar
BM08
yeah mate got a metal job for his st24
Old Aug 8, 2006 | 09:20 PM
lee23's Avatar
lee23
Default mondeo v6
James hi james just got your reply to my topic i found out it was the power steering pump leaking do u know if it is a hard job to do .
Old Aug 8, 2006 | 09:26 PM
lee23's Avatar
lee23
Default mondeo v6
xr4x4rs hi mate how hard is it to change the water pump and how common is it for the plastic propellors to snap
this is all new to me i think i mite go back to a 16v lol
lee23's Avatar
lee23
Default mondeo v6
Old Aug 8, 2006 | 11:24 PM
xr4x4rs's Avatar
xr4x4rs
very common for them to snap mate
id change it to be on safe side
never done one but my mate done his and said never again
Old Aug 9, 2006 | 07:36 AM
The Youth.'s Avatar
The Youth.
the water pump is very easy to change takes about 30 mins max.
reove plasic cover fro front f engine on the battery end of the engine you will see the wp drive belt remove it then undo about 8 bolts from the pump cover drop pump down to floor.
to fit new pump lift it in from underneath tie some wire to it to lift it up is easier then redo the bolts up and refit belt and cover job jobbed, if you have trouble finding a metal pump partco sell them for 50 odd quid.
power steering pump is fairly easy aswell it's on the top of the engine opposite end to the w pump reome engine mounting first.
steve
Old Aug 10, 2006 | 10:09 PM
James's Avatar
James
isn't the power steering pump on them driven from the cam on the gearbox end?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
