COSWORTH PARTS CLEAROUT, ENGINES, ETC ESCORT+SIERRA LOOK!!!!
Old Aug 6, 2006 | 12:55 PM
Kevin Sharp's Avatar
Kevin Sharp
Default COSWORTH PARTS CLEAROUT, ENGINES, ETC ESCORT+SIERRA LOOK!!!!
Right here goes after alot of dillemma i have decided i,m breaking my escort .....engine and box are up for grabs first, onece one of them goes i will list the rest of the stuff
for those of you who dont know my car, performance figures with this engine/box combination fitted in a lardy lux pack road trimmed escort were
0-60 in 2.94 sec with 50shot of gas
0-60in 3.017without gas
0-100in 6.3sec again with 50shot of gas
1/4 mile 10.88@132mph no gas
1/4mile 10.3@142mph with about 100or so shot of gas
ENGINE:SOLDoriginally built by turbosystems for me in 2003
this has just been stripped checked and rebuilt by them.
brand new crank/rods/ pistons/followers/isky valve springs etc etc
late eek4 escort block long studded with wrc headgasket.
HEAD this was brand new when the engine was originally biult and ported to RS500 touring car spec
RS500 8inj plenum with 8 greens
T4 turbo just been reconned by turbo technics
bigwing gated sump
as you can see virtually everything is brand new on this.
£10,000 or £8000 without 8inj setup and turbo
FFD 7speed box:SOLD i,m selling this as a complete package comes complete with belhosing,hydraulic centre push thrust,front and rear props to suit it, ap twin plate clutch with brand new plates,modified flywheel,startermotor, grp a xmember modified by DOME to fit to standard shell mounts, dry sump tank,
done 2 track nights since checked over by DOME /BARRA
60/40 drive split
17/26 ratio
60nm vc
this gearing pulls 180mph in 7th with 3.6 diffs on 245/40/18 tyres @just under 7krpm.
this fits straight into your escort or saff with some minor trimming required round gearlever hole
£10,000
400bhp engine as taken in PX for my 500 one above...this engine was actually mine originally built back in 97 and sold to the present owner in 2001....rebuilt less than 18 months ago using BRAND NEW 200 BLOCK!, 7.2 low comp, ported head matched to inlets, bd10 cams ,greys, turbo is a BBR hybrid thingy not 100%sure on spec but its almost T4, comes complete with ecu and turbosystems programme to run it, perfect motor priced to sell at £3250.... still in davie,s sapphire at present and can be heard running till mid week
Standard escort cosworth engine, was running perfectly removed from a 65k mile 1993 car, dry stored for 2 years... but properly with bores fillled with oil and turned over regularly, £1850
not much stuff left now......
escort cosworth eek4 block (yes its the one with the oils spray jets)bored to .50 . no 4 has a liner fitted, bores are in excellent condition £250
pair of front hubs mint £125
pair of as new genuine ford (2 tracknights) front driveshafts with reinforced inner tripod joint sleeves £425 SOLD
RHD bulkhead underbonnet plastics £75 SOLD
escort cosworth set of heater vents for behind dash£60
escort cosworth Heater box/matrix and controls £100
escort cosworth RHD steering rack £100
pair of composite motordrive seats in black with brand new sidemountings, seats had been fitted to a car but never used weigh only 3.7kg each £550
escos steering wheel..not mint but useable £60
escos steering column with key £50 SOLD
brand new tarcal breather tank £160
escos column swithces £40 SOLD
8 injector subloom £50
set of 3 door clocks £55
pair of escort cosworth front wheelarch liners mint with new fixing torx bolts £80 SOLD
escort cosworth rear anti roll bar mint £75
escort cosworth front polybushed anti roll bar mint £45
escort,saff/4x4 cosworth polybushed track control arms, mint off my own car only 2000 miles mint £60
escort cosworth front ally Xmembers £35
cosworth dizzy and phase sensor £40
cosworth 2wd exh manifolds perfect with no sheared studs 2 parts £45
rs500 intercooler genuine £250
2x 2wd diffs in need of recon, 1 with broken planetary gears, other one with chipped planetary gears. were both quiet diffs £make me an offer BOTH SOLD
escort cosworth rad/fans and lower metal pipe £100
all prices are inclusive of delivery and i accept paypal
i have lots of other odds and ends just ask
Old Aug 6, 2006 | 05:52 PM
Fiecos Dan's Avatar
Fiecos Dan
Good luck Kev.
What you fitting into your new shell then??
Old Aug 6, 2006 | 05:54 PM
markk's Avatar
markk
kev, i think you need a reality check pal
you dont honoustly think anyone on passionford is going to pay out real money for decent parts do you ??????????
if it was £50 you ay stand a chance, but people have no real concept of quality parts on here pal, im not going to wish you good luck, there not be any luck neede to sell this type of goods
these are the second best gearboxes available for a 4wd cosworth, the first being made by xtrac,
Old Aug 6, 2006 | 05:59 PM
Kevin Sharp
Thanks Danny, i,m not fitting anything into it, i,m giving it up, going back to having one toy, my 3door..one 500+cossie is more than enough! 2 was just silly
mark, lol cheers! i thought i,d try on here first though
Old Aug 6, 2006 | 06:07 PM
KSA-Cossie's Avatar
KSA-Cossie
Gutted to hear that kev,is the 3dr your on about woolie from perth's old one ?
Old Aug 6, 2006 | 06:08 PM
Fiecos Dan's Avatar
Fiecos Dan
So not gonna be chancing the 9 second 1/4..
Old Aug 6, 2006 | 06:12 PM
Kevin Sharp
Kev, yep thats the one, over 10years i have had that now!
Danny no no 9 sec1/4 now i just cant be bothered with it anymore
i,m 36 now must be an age thing
Old Aug 13, 2006 | 12:41 PM
dovboy's Avatar
dovboy
time for a porsche 911 is it old yin?
Old Aug 13, 2006 | 06:38 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
36 kev, your still a pup mate, fly the flag for us scots mate
Old Aug 13, 2006 | 06:43 PM
Rene's Avatar
Rene
sorry to see it being broken mate but hey
Old Aug 14, 2006 | 09:38 AM
NEIL A's Avatar
NEIL A
Take it the 380's will be going on the 3 door kev so what you doing with the 360's off of that.
Old Aug 14, 2006 | 09:28 PM
Kevin Sharp
aye i will be flying the flag..its just it will be hanging out the window of something like a porsche gt3rs
neil ring me if your interested in them they could be yours they are 355,s
Old Aug 14, 2006 | 09:32 PM
KSA-Cossie's Avatar
KSA-Cossie
I can still remember the 1st time you took it to knockhill,it looked a lot better after you fixed it anyway !
Old Aug 20, 2006 | 09:17 PM
Kevin Sharp
engine sold to dovboy thats another taxi iv to put an engine in!
gear box also sold to PF member but i,m not sure if he wants to remain annonymous!
loads of quality cosworth stuff here this week! http://search.ebay.co.uk/_W0QQfgtpZ1...ssZkevQ5fsharp
Old Aug 20, 2006 | 09:21 PM
Ryan's Avatar
Ryan
Kev whats happening about the front brakes? ebay?
Old Aug 20, 2006 | 09:27 PM
Kevin Sharp
the 380 brembos? i,m undecided if i,m breaking my 3 door yet ..if not they will go on that
i have the front brakes off the turbosystems dessert spoon for sale 355mm 2wd fitment 6pot ap,s £900
Old Aug 20, 2006 | 10:54 PM
tregmatt's Avatar
tregmatt
sell they disks on they own and ul earn more money
Old Aug 20, 2006 | 10:56 PM
tregmatt's Avatar
tregmatt
kev i know u brake a few bits but have u gt the kick panel the one that covers the ecu in an escort cosworth
Old Aug 20, 2006 | 11:08 PM
Kevin Sharp
sorry mate no, but you have pm,s for the other stuff
Old Aug 21, 2006 | 10:34 AM
Ryan's Avatar
Ryan
kev if you've got some pics of the 355 setup can you pm them too me, and also a price on the 380 brembo's please, as im sure you'll decide to break the 3dr, as your in the breaking mood
Old Aug 21, 2006 | 10:41 AM
Kevin Sharp
i,ll get some pics later tonight ryan and i,ll reply to all pms later aswell
Old Aug 21, 2006 | 10:52 AM
capri-rs's Avatar
capri-rs
yes it is.
you dont have the rest of the pulleys for the small turbo escort??
cheers
Old Aug 21, 2006 | 05:04 PM
marco polo's Avatar
marco polo
Hi kev
i'll have the escort front grill please
Old Aug 25, 2006 | 04:43 PM
sfhsport's Avatar
sfhsport
Kevin Sharp
do you still have any 6 pot front calipers for 355mm discs?
Old Sep 4, 2006 | 10:45 PM
Kevin Sharp
BTTT sorry for not replying for so long
marco sorry the grill went with shell
capri RS the pulley iss nowsold but i do have other pulleys
sfh sport yes i still have 355mm 6pot front kit 2wd fitment £900 delivered
will make a fresh list up tomorrow........
Old Sep 4, 2006 | 11:12 PM
NEIL A's Avatar
NEIL A
Bonus if i take the brakes i'll get discount as i don't need delivery.
Old Sep 5, 2006 | 07:51 AM
Kevin Sharp
oh ok then
Old Sep 8, 2006 | 08:12 PM
Kevin Sharp
BTTT more parts and engines listed on first post!
Old Sep 12, 2006 | 08:46 PM
escossie560's Avatar
escossie560
hi would be intrested in underbonet plastic if in good condition and stalk controls let us know cheers andy
Old Sep 15, 2006 | 02:40 PM
Kevin Sharp
BTTT more stuff listed!!
Old Sep 15, 2006 | 06:38 PM
Csm's Avatar
Csm
pm'd ya kev
Old Sep 16, 2006 | 07:02 PM
lamar69er's Avatar
lamar69er
how much for the wheel arch liners and bolts delivered?
Old Sep 16, 2006 | 07:45 PM
JHS's Avatar
JHS
I want those too...
Old Sep 16, 2006 | 08:46 PM
Kevin Sharp
all pm,s replyed to
sorry JHS liners sold to lamar69er
Old Sep 17, 2006 | 05:16 AM
JHS's Avatar
JHS
He was there first
You havent got the part numbers for the liners by any chance though?
Old Sep 17, 2006 | 09:49 AM
STUCOS's Avatar
STUCOS
Kev what about your pectel monitor
cheeRS stu
Old Sep 17, 2006 | 05:20 PM
Kevin Sharp
sorry dont have part numbers as i already have them boxed and ready to go!
Stu, sorry monitor is getting kept for the 3door....
manuel boeckx
13
Oct 3, 2015 02:29 PM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
Old ford
Jul 31, 2015 06:50 AM
