Turbo Glowing Orange
Old Aug 5, 2006 | 09:58 PM
Brian's Avatar
Brian
Default Turbo Glowing Orange
Anyone know why
Just come back from southend come off the slip road onto the A127 put my foot down and the car felt a bit sluggish pulled in to the petrol station for some fuel and could see steam from the bonnet vents so i openned the bonnet and the turbo was glowing orange
All i have done was take the dump valve off today as the car kept cutting out which it hasnt done yet since the dump valve has been removed.
Anyone got any idea's why the turbo is glowing orange?? is this ok?? what will stop it happening??
Brian
Old Aug 5, 2006 | 11:17 PM
RST Ski's Avatar
RST Ski
turbo's getting to hot, does the compressor whell spin freely in it? sounds like its oil feed may be blocked to it or somthing, havnt disturbed any of the pipes?
Old Aug 6, 2006 | 12:09 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
if your givin it stick then it'll glow orange/white, usually running too much ignition advance will make this happen prematurely! (i.e. get really hot really quick)
check oil and water feeds, maybe the turbo is on its way out and the compressor is touching the housing?
Old Aug 6, 2006 | 12:18 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
I used to try and make mine glow
It looked good at the time LOL
Old Aug 6, 2006 | 11:18 AM
rstdave's Avatar
rstdave
They will glow if u've bin givin it a lot of stick, especially if u've bin loadin it up in the higher gears on a motorway or somethin, so much heat bein generated!!! Just try and make sure u give it a run down period before swtichin the car off!
Old Aug 6, 2006 | 01:00 PM
stuart collins's Avatar
stuart collins
this is wat mine looks like when its bein mapped
Old Aug 6, 2006 | 01:21 PM
vroooom ptssssh
It Wasnt Me!
stuart collins, Looks mad! purple
Old Aug 6, 2006 | 02:08 PM
stuart collins
thats at 2bar of boost and over 7000rpm
Old Aug 6, 2006 | 02:14 PM
vroooom ptssssh
It Wasnt Me!
Ive saw them glow red/orange/white at simmilar boost on a stainless manifold but never purple!
Old Aug 6, 2006 | 02:20 PM
stuart collins
ive seen it hotter than that aswell , looks good tho
Old Aug 6, 2006 | 09:14 PM
Brian's Avatar
Brian
Cheer's guy's will have a look at the turbo and also check the oil feed pipe
That look's
Brian
Old Aug 6, 2006 | 10:43 PM
vroooom ptssssh
It Wasnt Me!
check the water feed pipe too!
Old Aug 7, 2006 | 07:34 AM
JesseT's Avatar
JesseT
Too little ignition advance, wrong timed cam, or lean mixture will usually be the reasons for too hot exhaust temperatures.
Old Aug 7, 2006 | 03:20 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Proper abuse
Will a ceramic coated manifold still glow like that?
RSBryden
Sep 6, 2015 08:39 PM
liam-rst
Was It You?
Sep 5, 2015 06:38 AM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
