Cossie Alternators UPDATE*****
i got mine re-conditioned afew times at a local place..
new brushes and regulator..wasnt expensive
they last about 4 to 8 years on average
how long you had the cossie
2wd or 4wd mate
i got one here came off a early 4wd car but is a 2wd one
worked last week when i broke the car
if you want it come and collect it as im gona chuck it away
or if you cna get a pic of what yours looks like i can say yes or no if its the one ive got saves a journey for nothing
start your engine and put a volt meter across your battery
should read at least 13.5v
ill be in all day tomorrow chads got my number if your going to see him im only round the corner from there anyhow
or you could just start the car then take a wire from the blue connection on the alt and touch the posative on the battery and that will turn on the alt and see if that sorts it
if you got no bat light on the dash then tbh thats the problem as that coninues the circuit for the alt to turn on mate
check stupid things first - make sure the dash warning light and blue wire as stated is ok. You can check by earthing the blue wire at the alternator end with the ignition on, that should light the charging warning light.
Originally Posted by Shings
Blue wire - this comes off the back of the alternator and into the loom and goes to the instrument panel on the dash.?????
Jake
Jake
sorted
sounds like that tbh
this means the lamp and blue wire are OK so the problem lies at the alternator:
1, Brushes are worn out
2, Regulator/diodes broken
3, Alternator body not earthed
if it's 1, or 2, then you're best just changing the alternator (no offence, but from the questions you are asking it's unlikely you will be repairing the internals..?)
3, is fairly unlikely but may be worth checking continuity from the engine block to alternator body.
Originally Posted by b19bal
A YEAR
christ,,,,,,, id want more than that out of my oil
Plus he said it has lasted a year SO FAR! Not that it has failed again after a year!
jonfoc
16
Sep 11, 2018 05:35 PM
Russ Payne
Sep 25, 2015 08:29 PM
