stu help!
Old Aug 16, 2004 | 10:51 PM
weegaz22's Avatar
weegaz22
Default stu help!
need some advice, ive have a problem with the boost dropping off, i thought it was a dodgy actuator at first so replaced it with a new one...still the same, had a look at the hose from the turbo intake to the metering head, thought it was collapsing so cut it back slightly (too much material on it so it was bent more like an "S" instaed of a "~", if you get what i mean)
still doing it, now the only thing that i can think of is that the seal on the compressor housing is leaking, the car goes up to 15 psi...then starts to drop off until 7-10psi, any ideas?
i think its a leak to be honest as its not doing it at a set rpm, as when it drops off to 7/10psi, you can take the foot fully off the pedal press it to the floor and it will come back in at 15 psi then drop off again
its an 89 erst
cheers in advance
Old Aug 16, 2004 | 11:36 PM
escort1989uk's Avatar
escort1989uk
have you got standard hoses they may be collapsing under boost but don't quote me on it
Old Aug 17, 2004 | 12:01 AM
weegaz22's Avatar
weegaz22
samco's
Old Aug 17, 2004 | 01:16 AM
xr-stu's Avatar
xr-stu
id check all your bosot hoses and vacum hoses.
a mate of mines xr2 turbo (a11 xrt) was doing this exact thing....would hit 15psi...then drop down to 5-7psi. just randomly started......didnt use it for a while and its fine now.
id check all boost hoses though mate
Old Aug 17, 2004 | 08:29 AM
weegaz22's Avatar
weegaz22
ive checked all the boost hoses, they seem fine, only one that was suspect was the turbo intake hose, its got a new intercooler as well so its not as if its that was leaking
knackered amal?
knackered compressor housing seal?
checked the shaft for play and it seems fine, about 1 mm of movement side to side
any other ideas?
Old Aug 17, 2004 | 09:30 AM
weegaz22's Avatar
weegaz22
Old Aug 17, 2004 | 03:15 PM
weegaz22's Avatar
weegaz22
and again
Old Aug 17, 2004 | 06:34 PM
weegaz22's Avatar
weegaz22
help lol
Old Aug 17, 2004 | 06:46 PM
Spiky's Avatar
Spiky
leaking wastgate on turbo?????
Old Aug 17, 2004 | 06:55 PM
weegaz22's Avatar
weegaz22
quite possibly, im not sure, wouldnt it just loose the boost stright away instead of going to 15 then down to 7psi?
GTR_STU
Aug 28, 2015 01:02 PM
Bailes1992
Aug 16, 2015 07:14 PM
