Series 1 fuel pipe dilemma
Old Aug 3, 2006 | 08:49 AM
Russ Payne's Avatar
Russ Payne
Default Series 1 fuel pipe dilemma
Hey everyone, will a series 1 fuel pipe that runs from the pump to the accumulator fit a series2 or are they different
Old Aug 3, 2006 | 11:35 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Think it's different as on an S2 the acumulator is in the engine bay afaik!?
I used the metal banjo on the fuel pump, clamped a rubber fuel hose to it, cut the plastic hose at the accumulator end and pushed the hose over that with a clamp and had no problems!
HTH
Old Aug 3, 2006 | 11:55 AM
originalcabbie's Avatar
originalcabbie
S2 accumulator is located in the engine compartment, while the S1 is located next to the fuel tank. the option above seems the best way to go. Make sure that the fuel pipe is rated to above 6 bar of pressure otherwise you will have splitting issues which I previously had when doing a bodge repair to get me home one night!
155lee
Sep 6, 2016 11:10 AM
155lee
Oct 27, 2015 04:55 AM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
Bransby
Sep 11, 2015 01:09 AM
kevin36
Sep 8, 2015 12:23 PM
